G development with labview
hello everybody.
I managed to do a small web application with G web Development software, right now I want to make a simple UI with G web development software for a pre-made Labview program.
how can I communicate between the LabVIEW and G web?
thank you.
(1,589 Views)
When using NXG in a WebVI, I had it communicate to classic LabVIEW using File IO stuff.  Basically having one program write a file, and then having the WebVI read the files contents.  But since then I heard that WebSockets is a pretty easy way to do communication to and from a web application.  There is a WebSocket toolkit for LabVIEW and NXG had a WebSocket API.  I'm unsure if the G Web Development has one or not.
(1,504 Views)
