GAC Warning using .NET Status Bar
I'm currently developping an application where I integrated a Status Bar using a .NET container.
Each time I'm modifying the diagram or running the application, this message is dispalyed :
"D:\Dev LabVIEW\JTEKT-Banc_Acquisition_Codeurs\Banc Acquisition Codeurs\BancAcqCodeurs - Top-Level VI.vi
    - The .NET assembly expected to be at "D:\Dev LabVIEW\JTEKT-Banc_Acquisition_Codeurs\Banc Acquisition Codeurs\BancAcqCodeurs - Top-Level VI.vi\<GAC>\System.Windows.Forms" was loaded from "<GAC>\System.Windows.Forms".
I've seen on a ressource page that this warning disappears if a custom control containing the status bar is created. Bt it didn't help a lot for me...
Does anybody have an idea to force that warning to disappear ?
Thanks !
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,566 Views)
Are you using Labview 8.5?  Take a look at this message thread that discusses a similar error message as yours.
(3,541 Views)
