GET file from cRIO using WebDAV - error (363510)
Hello everyone,
I'm trying to get a file called "test.txt" which is located in the following path: http://169.254.223.190/files/home/lvuser/natinst/bin/test.txt of my RT-Target (cRIO-9047).
here is my code:
According to this source: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH93CAG&l=de-DE there is different ways to enter the path depending on the processing system. Since cRIO-9047 uses the NI-Linux Real time my path (the string constant) form must be correct.
My local path (the path constant) is on my host-pc which is based according to the last source on this form: C:\Users\localuser\Documents\LabVIEW Data\the_test.txt
However, this path is automatically switched to the NI-Linux Real time form: /C/Users/localuser/Documents/LabVIEW Data/the_test.txt I guess the reason behind this is the fact that my code is running on my cRIO-9047. I thought this could the part that causes the error 363510: LabVIEW: (Hex 0x58BF6) An error occurred while writing to the socket. So I tried this solution:
It didn't solve my problem though 😥 Can anyone here help me please?
best regards,
Ezzow
Message 1 of 1
(1,380 Views)
