GFT9404 delay card
We are using NI GFT 9404 delay card on a NI PXI chassis, in the staus menu, there is an active falut named Oscillator which is on all the time, how can we get rid of this fault? is that a software problem or hardware related to the chassis or card itself?
(2,686 Views)
Hello Seadat,
According to the board User Manuel, this FAULT led indicates one of these errors (page 10 of https://www.ni.com/pdf/manuals/GFT9404_Manual.pdf😞
- Loss of 10 MHz PXI backplane
- PLL unlock
- Oscillator unlock
To know exactly what error/s you are having, check the Status Windows (page 17). Usually, these errors are owing to hardware problems so double check if the board is properly installed in the chassis.
(2,634 Views)
