GOOGLE MAPS ROUTE
Hello everyone,
I have found and used this Vis cointaining google maps application, that allows you to indicate different locations and give a Google Maps window indicating them.
Now. I'm not really familiar with this specific application.
I would like, indicating  2 locations, to have also the driving route between them. Is this possible?
If the 2 locations are saperated by ocean It's OK to have just a Line connecting the 2 points.
Would you be so kind to help me?
I attach the ZIP with the VI,
Thanks a lot
(3,354 Views)
They told that I should look inside the "Get Map" SubVi and then inside the "HTTP Get" SubVi and change the command to add the route.
But I am very not familiar with that.
Does Anibody have an idea?
Thanks a lot
(3,270 Views)
