GPIB PROBLEM
The Gateway Address should be the same as your PC's static IP address (192.168.1.2).
Message 61 of 66
(1,671 Views)
Uh-oh, now you've done it.  He can no longer reach the internet.  😉
Bill
CLD
(Mid-Level minion.)
Message 62 of 66
(1,655 Views)
@crossrulz wrote:
@nizam2 wrote:
Do you mind if i ask? How to connect my TD3012 to my laptop?
We are recommending an Ethernet cable
Is that a "Royal WE?"Heart
Yeah He has a point though.
routers are fairly cheap it your IT department premits them
Message 63 of 66
(1,633 Views)
No, there were others in this thread that recommended the Ethernet cable.
And you don't even need a router.  A simple, really cheap network switch will do as well if you use static IP addresses.  I made a whole test system work that way and it was beautiful how everything played together.  And it was A LOT cheaper than GPIB.
Message 64 of 66
(1,623 Views)
A router would allow you access to the internet while still being able to communicate with your equipment in DHCP mode... IF your IT allows that.  I guess he never figured out how to get back onto the internet after he set his static IP address.
Bill
CLD
(Mid-Level minion.)
Message 65 of 66
(1,608 Views)
In my world, Test System = not connected to any outside network (including company network).  I will network a few test systems to keep a local repository, but they do not go beyond that.  I do this for performance (no need for the firewall, virus scan, etc.) and stability (I know exactly who has what IP and it never changes based on how a router feels that day).
Message 66 of 66
(1,585 Views)
