GPIB-USB-B
I have a problem with the Labview realtime environment. I have compiled an EXE version of a VI. The VI is used to control some equipment using GPIB-USB-B hardware converter (a small box that allows you to connect GPIB to a laptop computer for example. I have installed Labview Realtime and visa441runtime and it still does not work. Windows Vista searches for a driver but does not find one. Do I miss some component?
Thanks for your help,
David
(3,878 Views)
I think you mean LabVIEW runtime and not realtime. The two are very different.
In any case, you did not list NI-488.2 and that's an essential driver for a 488 controller.
(3,871 Views)
Oups, you are right. I wanted to say runtime and not realtime ... :smileywink:
So I need to install Labview runtime and NI-488.2 in order to execute a compiled EXE Labview program, correct?
(3,854 Views)
