GPIB-USB HP3562a...
Here's the error eraser in 8.0 format? Performed a save for previous versions...
Message 21 of 31
(1,945 Views)
Hmm, no reading response yet. :-(.  I will try the HP3562a driver from NI website. Maybe I will have some  progress with this code.
Message 22 of 31
(1,941 Views)
I think I got some progress with the reading. It appears that in order to read  the data a new query is required  after the writing sequence to the analyzer.  I used the NI provided  driver which was written by another student.
Message Edited by RSibagatullin on 05-29-2008 01:52 PM
Message 23 of 31
(1,936 Views)
OK, so I was not able to figure out how to use RDMK command (read marker) and I have decided to calculate power at particular frequency by means of LV rather then marker apparatus in HP3562a.  Numerous experimennts showed that software acquasition results in less then 0.01% error compared to the marker value hardware based measurement.  I have atthached the code which shows how  to pool the whole plot from the analyzer and disretize it in 800 bins. I used the NI driver with a few changes to it. Thanks.
Message 24 of 31
(1,911 Views)
Does anyone know how to get the x-axis data?  When I do the Coordinate Transfer Dump it gives me y-axis data and the also some valuse from 0.99999 to 5.99999.  Can some HELP!!!!
Message 25 of 31
(1,606 Views)
Wow, this thread came back alive!
I think the number you're missing is 801.  I believe there are 801 samples, so the frequency goes from A to B in 801 samples with so many samples at each frequency.  You also have to figure out what the units are from one of 35 possible enumerated types.
Good Luck!
Message 26 of 31
(1,594 Views)
I apologize but I have no idea what you wrote on your reply.  I am completely lost with this instrument.  I have attached what I am using to collect dat from the instrument.  The date I receive is y-axis data (801 samples) and also another data points which range from 0.99999 to 5.999999.  I am doing a frequency response from 1Hz to 100kHz.  Please help me to understand what does 0.99999 to 5.999999 numbers mean and how I can convert them to frequency.  The code is in LV8.2
Message 27 of 31
(1,586 Views)
Okay, I have access to "Contents of the Data Header" for Binary and ASCII data dump formats.
What index are you using? Binary or ASCII/ANSI?
What indecies are giving you the 0.9999 to 5.99999 numbers?
This has been done before, it will be okay.
Message 28 of 31
(1,571 Views)
I got bored...
Okay, I looked at the code a bit, get it? and I believe that the code is using the ASCII data dump,
0.9999 is the starting frequency or "Start Freq Value" and
5.9999 is the "Delta X-axis" or difference between each reading, however, there is a note that says 10deltaX for log-x axis, and since you're going from 1hz to 100kHz, I'm assuming the display is in log, so the delta is really 10 times 6 for each y.
So the code needs to be modified to multiply the delta times 10 in the For Loop in the Get Trace.vi, I think.
Good Luck.
Message 29 of 31
(1,566 Views)
Once again I am not familiar with HP's device driver code, so please bare with me.
Yes, it is using ASCII data dump.
I have attached the raw data file which I collected through the HP3562A.  If you don’t mind can you please show me an example how I can convert the data to frequency.
I really appreciate your help.  Thank you
Message 30 of 31
(1,559 Views)
