GPIB can't be configured in MAX
Hi everyone I am having a trouble with interfering the GPIB in Max.
All the options for GPIB are grayed (shown in the picture below) so i am not able to scan for instruments.
Any solutions? Thanks
(2,987 Views)
From the HELP window on the right side of the page in MAX
Note  By default, you must run MAX as an Administrator to change GPIB board settings. On Windows Vista or later, you also must launch MAX by right-clicking its icon and selecting Run as administrator. There is an option in the MAX Tools menu to allow privileges to all users for updating configuration settings.
Omar
(2,979 Views)
how can set the settings to make them ungrayed?
(2,973 Views)
I assume you are talking about the "Properties" tab and not the "Settings" tab.
You can only change the "Properties". I don't think you can change item that you show in your picture
I do not know why you can't scan
This is the Properties" tab that you can change
You can see the differant from not Admin and Admin
NOT as Admin        As Admin
Omar
(2,969 Views)
Check the "System Controller" and the "Autopolling" check boxes on the "Properties" Tab
Omar
(2,963 Views)
