03-10-2007 04:11 PM
03-10-2007 05:50 PM
What do you mean by 'show up in LabVIEW'? What kind of indication did LabVIEW ever give that they were present?
And no, in most cases, a non-NI GPIB board will not show up in MAX. However, if you are using an Agilent board (for example) and correctly install it's version of VISA and set the tulip passport, then it will. What is the make and model of GPIB board? Frankly, it sounds to me like both of the pc's might have gotten some sort of update that you are not aware of.
03-10-2007 05:59 PM
when you create a ViSA constant it gives you a list of all availible devices to assign it to, when the card is working it shows all the GPIB devices. when it is nt you just see the comm and serial ports.
I think I narrowed it down to hardware....I fixed one of the computers by moving the GPIB card to a different PCI slot and re installing it, the other one might be a motherboard fault (one of the techs told me the computer was "acting funny" since a power surge a few weeks ago, would have been good to know this at the start :P)
Andrew
03-11-2007 03:36 PM
