GPIB communication problem with labview only (not MAX)
I am using Labview to control a Keithley 2420C. The device is connected with a NI USB GPIB cable.
Sometimes the Keithley 2420C will just not communicate at all if I use Labview even though it will communicate perfectly with Measurement Automation Exporer.(MAX)
Restarting the computer solve the problem.
I dont understand how the communication can be made by MAX but fail with a simple "GPIB write" on Labview.
Please if you have any idea where the problem can come from let me know.
(2,637 Views)
Have you tried using the Instrument Driver from here?
Keithley 2420C Driver
You may have more success with it than using raw GPIB.
(2,627 Views)
First thank you for your help.
I was using such driver before and the problem was the same. I believe the drivers are VIs which use "GPIB write" and "GPIB read" of labview so if the drivers work a simple "*IDN?" ou "*rst" should work as well.
I will try those drivers anyway. I will write down a new post later to keep you informed of the result.
(2,598 Views)
If you can, go ahead and post your code as well.
It sounds like something is not getting initialized or cleared properly.
(2,594 Views)
