GPIB inconsistent behavior
A suggestion is to place some instruction complete? query instead of actual delay in ms.  😉  I forget the actual command for the HP SA..  I could look for it.
Glad it works 🙂  Continue to have fun with LV.
RayR
Message 11 of 27
(2,616 Views)
How do I check wtether my command is executed in HP3562a? It would be nice for me to know that so I can abolish my static delays.
Message 12 of 27
(2,598 Views)
I don't know what the command for this particular instrument is, but I would suggest just making your waits shorter and shorter until you start to get errors. That will accomplish the same goal, though it will take time to test.
-Marshall R
Message 13 of 27
(2,575 Views)
Here is one instruction to query if the instrument is done taking a sweep.
TS; DONE?;
TS aka Take Sweep , DONE? returns a 1 when the preceding command (TS) has been completed.
Message 14 of 27
(2,569 Views)
That is what I was doing. But this method is inefficient since different commands require different execution time. That is why I have to adjust the timer for  the worst case scenario.
Message 15 of 27
(2,568 Views)
Were you  referring to Joe's response or mine?  As long as it would take, you could tailor mine for every command, you would just have to test every command w/ different waits. Can't replace testing, unless someone else has done it for you 😉
-Marshall R
Message 16 of 27
(2,544 Views)
Message 17 of 27
(2,523 Views)
Message 18 of 27
(2,515 Views)
Multithreading forums is not as productive as Multithreaded processing! Smiley Tongue
-Marshall R
Message 19 of 27
(2,494 Views)
So I am trying to come up with a code which dynamically checks whether the analyzer is done with the measurement.
I  have attached the simple example.  As you can see the the code querries  the hardware in the while loop up  (SMSD command) up untill it receives sign of completion "1". The code works fine for like 5 - 6  while iterations but then gives me the GPIB 6 mistake  (timeout) in the GPIB write  VI  inside the While loop. I  am confused because when I write  I don't read anything and the write GPIB works fine for 5-6 iterations but then stops working. Moreover I don't have timeout on it so the reason for timeout is strange too.  I have read the NI GPIB 6 error description and none of the cases seem to apply to my situation. Please help me out.
Message 20 of 27
(2,438 Views)
