GPIB initialize without MAX
I am currently working on communication between two computers using GPIB. The scenario is such that one computer acts as a transmitter and the other receives the message string with two GPIB cards interconnecting them.
My problem is that every time i have to start communication i need to initialize my cards with MAX. Once initialized i have to keep running MAX in the background. If i dont do this the GPIB option doesnot appear in the VISA session or VISA find box. Is there any way to initialize GPIB programmatically in a reliable way without MAX? I have attached my programs for RX and TX, I will be very grateful if some one can edit them or tell me how to.
Thank you in advance.
(4,385 Views)
Hi Mylo,
Have you tried running any of the shipping examples to see if you run into the same problem? One in particular, LabVIEW - GPIB.vi, allows you to perform read or write operations between the instruments. It also refers to the "GPIB Initialization" function - this allows you to configure your GPIB interface specified by an address string. For VISA, try running the example GPIB - VISA.vi and see if the device is properly initialized.
(4,346 Views)
Yes even the shipped example doesnot initialize GPIB cards without MAX.
I even installed the latest drivers for 488.2, still no luck 😞
(4,335 Views)
Hi Mylo,
There should be no need to have MAX running in the background, you can try uninstalling the driver and then installing it again (488.2 Driver v 3.0.2), this will re-install MAX.
You can also check the following link:
Computer to Computer Communication Via GPIB
Eric NI
(4,316 Views)
Thanx for the response.
Do we have to use low level commands? cant we just use VISA functions with GPIB initialize?
(4,302 Views)
