GPIB readout from spectrum analyzer HP4195a
Does someone know how I can readout a HP 4195a spectrum analyzer with GPIB? I have a GPIB-USB cable. I can't readout the flopy disk from the spectrum analyzer in my PC.
Thanks, Ruben
Message 1 of 32
(11,829 Views)
Hi
I have a very old "generic" driver for this one
see attachment
greetings from the Netherlands
Message 2 of 32
(11,801 Views)
Thanks Albert,
I've tried your programs, I can give the S.A. commands, like SAVE and GET, but I'm still not able to readout the data from the S.A. into labview. I hope you have some experience in that?
Groeten uit Holland terug.
Message 3 of 32
(11,787 Views)
Call me on the phone, maybe a gpib card or installation problem.
one of the problems that can happen is a too speedy interface for an old instrument.
phone = 040 27 47234
Message 4 of 32
(11,785 Views)
Thanks for your offer, but due to some help I used your programs to build a new one, when it is finished I'll attach it here.
Message 5 of 32
(11,768 Views)
Hi Albert
I just want to thank you for a very nice driver for 4195A.
Although I have not tested it yet and I need to update it for latest VISA, I consider your contribution as a "Day Saving" help.
Your post is the only one on the whole developper exchange, which has this driver.
Thank you for that.
Do not want you to consider submit your driver to NI (http://sine.ni.com/apps/we/niid_web_display.sub_driver)
Then it will be accessible to more people.
thanks again
Cheers
Pawel
Message 6 of 32
(11,743 Views)
hello albert
i need help for my project to connect the hp 4193a with a usb/gpib interface 82357a to the pc and programming
with labview 7.1. i tried your driver but i dont have any connection on my pc.
if you can help me please call me
oliver ohme,berlin germany
0049 30 3828604 (homephone)
0049 173 2055497 (  d2 )
or email: 98rock@gmx.de
or give me yor number so that i call you.
with nice greetings from berlin olli
Message 7 of 32
(11,511 Views)
Hi Olli
Just a comment.
I have been using this converted with this network analizer. It works.... but you need to be carefull. Sometimes, the GPIB from network analizer will lock without a reason and even powering down will not change a thing. The only way to get it out of the lock is to disconnect it from the network analyzer.
good luck
Pawel
Message 8 of 32
(11,501 Views)
Hi Olli
the 4193 and 4194 are quite different, which driver did you try?
Message 9 of 32
(11,493 Views)
hello,
is the driver that you would build ready?
il search for a driver for labview 7.1.
what we want to do is the hp4195a connected with gpib-usb interface agilent 82357a to pc
programming with labview 7.1 so that all functions or the most where using over labview on pc and also to print the grafics with pc.
thanx and greetings olli
Message Edited by 98rock on 07-19-2006 02:47 PM
Message Edited by 98rock on 07-19-2006 02:51 PM
Message 10 of 32
(11,474 Views)
