GPS Record&Playback with NI2901
Hello All,
Is it possible to use NI2901 for GPS record and playback.
The following link mentions NI292x, but I wonder if my device is capable of doing such things.
https://forums.ni.com/t5/Software-Defined-Radio/GPS-Simulation-with-NI-USRP-and-LabVIEW/ta-p/3535408
Kind regards
(2,780 Views)
Since the bandwidth is higher and the frequency range is better, I'd say go for it.
(2,748 Views)
First of all thanks for your fast response, yes the device seems suitable for gps in terms of bw and frequency. However, the previous discussions and projects are based on much more sophisticated usrps. So, how should i start with this guy? İf you have any idea i will be happy to hear.
Regards
(2,739 Views)
If you have the software and the hardware, I'd start with downloading the example in the tutorial you're referring to, and simply running it. I don't have any of the software or hardware in my current setup, so I'm not sure if I can be helpful in other ways..
(2,733 Views)
