GPS Timestamp
I asked in the LabView and SignalExpress forums if there is a way to time stamp each fetch to account for clock drift without any luck.
http://forums.ni.com/ni/board/message?board.id=380&thread.id=1548
http://forums.ni.com/ni/board/message?board.id=170&message.id=431722&query.id=494967#M431722
I’m using fetch (size) in reference to the fetch size in the niScope Stream to Disk Queues Win32 File IO VI.  I normally set fetch size to 512000 so ideally I’d like a GPS time stamp for each 512000 sample set.
Is it possible to do the following:
1.       Set the Time Reference to GPS in the test panel for the 6682 in MAX.
2.       Under the TimeStamp tab choose an input terminal that corresponds to each fetch with the trigger type set to ‘Continuous’.
3.       Start the TimeStamp process.
4.       Start collecting data with the Win 32 File IO.vi.
I’m hoping that there will be GPS timestamp associated with each fetch.
I have a few questions with this approach.
1.
 Is  it workable?
2.       Is there a way to copy timestamps listed?  When I right click, choose ‘copy data’, and try to paste in notepad, nothing is copied.
3.       Would there still be some software latency so that the timestamp is not synchronized with either the start or stop or the data set.
Another solution would be to get a acquisition start timestamp (I can do this using the Time Stamp Trigger VI) and an acquisition end time stamp.  I’m not sure how to get end of acquisition time stamp.
I’m new to LabView and NI instrumentation so I apologize if these are naïve questions.  Thanks.
(3,697 Views)
annayaj,
I understand you have a rather complicated application here, but before you create new posts about the exact same topic I would give people a chance to respond.
Please let me know if any of these questions haven't been answered on any of the other threads.
Sincerely,
Jason Daming
http://www.ni.com/support
(3,626 Views)
