GSDML File
Hello there,
I have a peculiar setup. I need to connect our PC with a measurement software (master) to a PC with a LabVIEW program (slave) via a profinet network.
For this, I need the GSD or GSDML file, so that our side sees the LabVIEW-PC as slave.
Is it possible to generate this File with the LabVIEW Software? If not, how would you guys tackle this problem?
Furthermore, how can I give the LabVIEW-PC a PNIO-Device name?
Thank you very much in advance for your help and suggestions.
(3,985 Views)
I did a search for "GSDML LabVIEW", and found a number of "hits".  As I know nothing about GSDML or profinet, I can't judge if any of this is useful, but I did see mention of connecting a cRIO to such a network, so there is some history ...
Bob Schor
(3,932 Views)
the files are hardware/slave specific and LabVIEW does not have a function as far as I know that can create those files (how should LabVIEW know the information?).
Have a look here for information about GSD(ML) files. You can download some there or from the manufacturer of your device.
GSD Files
http://www.profibus.com/products/gsd-files/
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(3,897 Views)
