GUI custom design
I am interested in user designed GUIs like the one to be ssen here at the end:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1rdCAA&l=en-US
Does anyone know how to design such custom GUIs in LabVIEW?
step-by-step?
Regards
Joachim
(3,523 Views)
Did you actually try the tutorial?  If this is your first time with LabVIEW, you need to actually "do" it a bit, play around with moving/sizing/coloring Controls and Indicators (I assume you know the difference between these).  You can do a lot with the GUI elements that come with LabVIEW, but there are also other "custom" GUI elements out there, you just need to look around (have you checked the LabVIEW Tools Network?).
Bob Schor
(3,493 Views)
