02-21-2006 07:21 AM
I have an event structure which triggers on different boolean buttons.
Inside the event structures I have different sub vis that performs different tasks.
This sub vis contains loops which eventually terminates, but as long as they are running my main vi freezes and I’m not able to do anything. I have attached an example which I hope demonstrates my problem. The example is made with LabView 8.
I hope anyone can tell me what is wrong.
Terje
02-21-2006 07:39 AM
02-21-2006 07:44 AM
02-22-2006 01:15 AM
Thank you Jhoskins for solving my problem.
You are also correct about the second part. The stop button was actually only supposed to stop the subvi.
