GUIExecutableFullPath Error
I've tried like 20 times over to get labview installed but every time i get the same error. Some one please help, and yes ive already tried deleting hidden files, but that did nothing, and downloading the offline installer also did nothing.
(481 Views)
You are listed as a New Member to the LabVIEW Forum -- is it a good "guess" to think that you are new to LabVIEW itself?
You might have a serious problem, depending on a number of facts that you know but we do not.:
  1. How much experience/training/classes with LabVIEW do you have?
  2. Describe the computer (Operating System, including Version and whether 32-bit or 64-bit) you are using.
  3. What version of LabVIEW are you trying to load?  Include both "Version number" (e.g. LabVIEW 2024-Q3) and "level" (Base, Full, Professional, Community, etc.),   Are you installing 32-bit, 64-bit, or both?
  4. Describe (briefly) what components of LabVIEW (and what drivers) you tried to install.
  5. What did you do when you got an "installation failure"?
    • Did you try to remove the "failed" installation?
    • Describe (in detail) what you did.
    • Did you delete Files and Folders?  Describe as best you can.
    • Did you "edit the Registry" in any way?
  6. Do you have access to someone with LabVIEW experience who could install LabVIEW for you?
The "dangerous" step is #5.  Unfortunately (as I learned first-hand), LabVIEW installation is tricky to do "correctly" -- the temptation is "install too much, all at once" which can lead to "undo and try again", which can compromise the entire computer.
Once we have a better description of what you did, we can (probably) help you get LabVIEW installed.
Bob Schor
(440 Views)
