Gates on XY Graph
I did not think that you had this reading directly into LabVIEW.
You should be able to look at the example for GPIB communication in LabVIEW in the examples. Once you get the data into LabVIEW it is all down hill from there. Look into directly reading the data into Labview and send me the code once you have that working.
Tim
GHSP
Message 21 of 33
(1,993 Views)
Ok, I am trying,,,meanwhile;any suggestions to modify NI example?
Message 22 of 33
(1,988 Views)
Error occured at VISA write to GBIP-VISA.vi
Message 23 of 33
(1,983 Views)
I think that all we should have to do is replace the part that generates the data:
24166iFA00F726155C3939
Tim
GHSP
Message 24 of 33
(1,977 Views)
I replaced it with the recorded data from Labview signal express (converted the signal to labview code and put it instead of scan data),,,it did not work.
But as per your proposal it will be easier since we are going just to focus on how to bring GBIP data
Message 25 of 33
(1,974 Views)
but i think it is about the scope not the GBIP isnt it?
Message 26 of 33
(1,972 Views)
How are you talking to the GPIB at the moment?
Tim
GHSP
Message 27 of 33
(1,969 Views)
the GPIB is bringing data from the oscilliscope, GPIB,VISA 4.6,Tektronix software are installed, when I open labview signal express I use acquire data feature and I find my oscilliscope easily
Message 28 of 33
(1,967 Views)
I tried to use this but also did not work....what do u think?24168i859ED4E3B51C253C
Message 29 of 33
(1,956 Views)
I do not have a lot of experience with GPIB. Maybe you can post a seperate question for the GPIB communication and we can go from there.
Tim
GHSP
Message 30 of 33
(1,951 Views)
