Gaussian Fit Assimetric
I would like to know if somebody developed a VI to do a fit for an assimetric gaussian curve.
(5,965 Views)
you can find it in Signal Processing Palette.
Regards
(5,959 Views)
Please be more helpful. That palette contains a lot of functions, and I am not aware of any that fits data to an asymmetric gaussian curve. Please give the exact name of the function, or even a link to the online help page.
 LabVIEW can fit for anything, asssuming you have a mathematical description of the model.
Do you have a specific model in mind, for example:
Once you have decided on a mathematical model, use nonlinear curve fit an write an appropriate model VI using the template
What kid of data is this? Can you attach some sample data?
(5,955 Views)
There are many VI's that ship with LabVIEW that help with Gaussian fitting. Here are the ones I found by searching 'Gaussian' in the Functions Palette:
Fitting:
  • Gaussian Peak Fit (Mathematics > Fitting)
  • Gaussian Peak Fit Intervals (Mathematics > Fitting > Advanced Curve Fitting)
  • Gaussian Peak Fit Coefficients (Mathematics > Fitting > Advanced Curve Fitting)
Signal Processing:
  • Gaussian Window (Signal Processing > Windows)
  • Gaussian Monopulse (Signal Processing > Signal Generation)
  • Gaussian White Noise (Signal Processing > Signal Generation)
  • Gaussian Modulated Sine Pattern (Signal Processing > Signal Generation)
  • Gaussian White Noise PtByPt (Signal Processing > Point By Point > Signal Generation PtByPt)
  • Gaussian White Noise Waveform (Signal Processing > Waveform Generation)
If these do not work for you, can you provide more information on your application?
Jared A.
(5,889 Views)
Thanks a lot I think I will try to do a log normal distribution and use the General Fit vi. Many thanks for your help
(5,885 Views)
@jallen88 wrote:
There are many VI's that ship with LabVIEW that help with Gaussi...
These all deal with symmetric gaussians and thus don't answer the question...
(5,881 Views)
