General LS Linear Fit PtByPt
I am using the General Linear Fit to fit a plane to a set of X,Y,Z data.  I would like to perform this same calculation as the data is being collected and was hoping the General LS Linear Fit PtbyPt VI would be helpful.  However, I don't understand the data inputs for this VI.  Fot eh General Linear Fit VI, H is a 2-dimensional array with dimensions m*n (where m is the number of Z data points I have and n is the number of fitting parameters: 3 in my case - b0, b1, b2 - according to the equation Z = b0 + b1*X + b2*Y).  For the PtbyPt VI, if I wire a 2D array to the H input, the resulting wire is broken, claiming that the input should be 1D.  In that case, how should H be formatted.
Thanks in advance.
(3,093 Views)
Hello
The PtbyPt functions are working on one and only one point you provide them. You can't give them the whole array. Look at the VI I attached, I think it should explain the problem (sorry for a little mess in the block diagram, I've made it from General Linear Fit example and didn't bother to clean it up).
(3,079 Views)
