General linear fit with 2d arrays: is it possible?
Some days ago I learned, thanks to altenbach's VIs, how to perform a polinomyal fit Z=f(X,Y), where X,Y,Z are vectors. Now I ask if it is possible to perform a polynomial fit of such type: (Z1,Z2)=f(X,Y), where now I have 2 vectors Z1 and Z2.
I haven't found any documentation about it. I don't know how to build the H Matrix, and I don't know what to send to the y input of the general fit VI. To be true, I don't even know if it is possible, but I hope it is. All the 4 vectors Z1,Z2, X1,X2 have the same dimension.
Could you help me? Thank you
(3,808 Views)
LabVIEW is a full featured programming language, so anything is possible.
You need to explain in more details how your data looks like. What is x and y? How do Z1 and Z2 depend on the paramters and x and y? You want to simultaneously fit to two surfaces? What is the model?
(3,793 Views)
Thank you. I have just found this article http://it.mathworks.com/help/stats/multivariate-general-linear-model.html , that explains the model and how to implement it. Tomorrow I am going to try. As far as I can understand, they suggest the method of interleaved arrays.
The Z1 vector is a vector of data that I succesfully fitted with X and Y some days ago. The Z2 vector is another set of data that I didn't use in the analysis so far. What I realy need is the fit that I did last week. I am curious to see if something change if I use the Z2 set of data to perform a simultaneous fit. I am not sure, because the number of parameters increases.
(3,778 Views)
I tried the bivariate general fit, as described in the above link and the result is exactly the same as in the single fit. I read somewhere in the web that this is correct (that is nothings changes as respect to the single fit). Nevertheless, I am quite surprised and disappointed because of that. Anyway, if someone wants to play with general fits with 2 vectors, here there is the png to modify the H matrix. The vectors to be sent to the fit have to be interleaved and eventually decimated.
(3,731 Views)
You are not adding any new or useful information. Can you show us the rest of the code?
(3,722 Views)
