Generate 1.5th order wheel torque
Hi
from vehicle i am getting parameters Wheel Torque (nm), Engine speed (rpm), Main shaft speed (rpm) with respect to time in 2d array, please guide me to generate 1.5th or nth order torque from that?
Thnx
Prashant
PRASHANT SONI
SOFTWARE ENGINEER-LabVIEW
(3,118 Views)
Have you tried anything or thought at all about your problem before posting here?
(3,108 Views)
Do you have problems with the math or with programming?
(3,099 Views)
 HI
I have attached the logic, but i m getting expected results so i hv doubt like i am using correct formula for getting 1.5th order wheel torque. So i need to help in finding correct formula or logic. i dont have any issue with programming just need help in finding correct logic.
Thank you,
Prashant
PRASHANT SONI
(3,093 Views)
What is the formula?
(3,089 Views)
