Generate 10 random numbers
Hi, can you help me with this?
Generate 10 random numbers and put them in an array
then save that array as a text file on a computer disk named data.txt.
(2,314 Views)
Hey, can anyone help me with this?
Generate an array of 10 random numbers in a range
from 45 to 55 and then find the arithmetic compound
and the standard deviation of that array. Show the result graphically and on a histogram.
(2,296 Views)
What have you started?  Where are you stuck?
It is a pretty simple task when you break it down into the simple tasks that are defined in those few sentences.
(2,276 Views)
Obviously your teacher feels that you should have enough knowledge to complete this task.  Let's see what you have so far.
Bill
CLD
(Mid-Level minion.)
(2,269 Views)
This sounds like homework.
What have you tried?
Have you followed the in class lessons?
Have you looked at the free online tutorials?  How to Learn LV
(2,251 Views)
Once you solve your other almost identical problem, it will be easy to modify the old code for the new requirements. How far did you get?
(2,247 Views)
