Generate 1PPS signal from PC clock and show it on TIC using NI DAQ
Hello
I am creating a vi to generate 1PPS signal at NI DAQ USB 6008 from PC clock which is synchronized with NTP server. And transmit this signal on TIC.
I am new to LabVIEW, so kindly help me.
Thanks in advance.
Abhinav
(3,280 Views)
Where is the code you've done so far?
Where are you stuck?
Have you gone through the tutorials?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,274 Views)
Hi abhi,
LabVIEW comes with a lot of examples.
There are also example VIs showing how to output digital signals (like your pulse) using a simple USB600x device. Just open this example VI, study and understand it, then apply your logic to output a pulse each second…
Remark:
When asking questions in the forum you should not use so many abbrevations. Try to explain as much as possible!
(What exactly is "TIC"?)
(3,272 Views)
