Generate 2 different sounds with the PC 5.1 soundboard and 2 sets of speakers
I need to generate multiple (for now, 2) diferent waweforms on my speakers. Eventualy i will use a DAQ echipment, but, for now, i have to use my PC. So, i have a lots of speakers, i manage to output diferent waweforms throught them, and I wonder if I somehow colud use individualy two of my soundbord outputs simultaneously, and generate difernt waweform sound on each. Thanks.
(2,764 Views)
Hi Vameanu,
I am not too clear on your question. It's seems that you have managed to create a variety of waveforms in multiple speakers and now you want to use two sound cards. Could you be more specific as to what VIs are you using? Are using the sound VIs? Are you using two sound cards to produce sound in two separate speakers?
I found two forum posts that help with different sound generation;
Hopefully this helps.
Aashish M
CEO
TransferFi
www.transferfi.com
(2,751 Views)
