Generate Button Press Event at Timeout Case in Event Structure?
We have a complicated "Event Structure"  Labview program, there are buttons for "Start", "Test", ...   . Each button has its "Value Changed" case in the Event Structure, there is a "Timeout" Case as well.
I would like to insert some code to automatic test those buttons rather than manually press button by mouse.  I am thinking to use the "Timeout" case to generate "Value Changed" Event for each button, Is that possible?
Regards
Samuel
(4,147 Views)
To trigger an event, you would write to a signaling value property of the control. One problem is the fact that your start, test, etc buttons are probably latch action, preventing the use of value properties. This means a little bit more code.
I don't like the thought of triggering events in the timeout case. Maybe an state machine would be a better choice. One state could be "continuous".
Would you mind attaching your program so we get a better idea what your questions is all about?
(4,140 Views)
