Generate Constant DC Voltage
Hi all,
Is my program correct? I want to generate a constant DC voltage and can I modify this program as attached by setting 0hz and a offset value which was used to generate a sine wave previously?
Shouldn't the DC voltage appears after 0.1s too?
(2,946 Views)
The program is silly if you just want a DC level. Set the polymorphic type of the DAQmx Write to Single Channel>Single Sample>DBL.
(2,923 Views)
