Generate Event when a plot on waveform graph/chart is clicked
I wonder if it is possible that I could trigger an event when one of the plots on a waveform chart/waveform graph is clicked when mouse-cursor is hovered over the plot and left key of the mouse is pressed down??
Any ideas?
Best Regards
K Waris
(3,609 Views)
Yes there is. In your event structure, click the graph in the "Controls" tree and then click "Mouse" in the events window. Normally LabVIEW defaults to just show you the Shortcut menu, but there are plenty of other events you can capture. Two of these are "Mouse Enter" and "Mouse Down".
(3,605 Views)
