Generate Finite Square Wave Pulse for an AO Channel
Hi all, I am trying to generate a finite square wave pulse from an AO channel of my DAQ device... The pulse will trigger external equipment...
The pulse should have an amplitude of 2 volts and a pulse width of 1ms... There need to be controls to set the number of finite pulses and the frequency (pulses/sec) at which the pulses are written..
I have attached a vi I have developed that currently works... However, it seems overly complicated for what I need and the number...
Any suggestions for how it could be simplified?
Many thanks.
(654 Views)
Not too bad.  I would straighten out the Error Line linking the DAQmx functions, put the Function Generator on a parallel Error Line (perhaps merging it with the DAQmx Error Line), and try to make the zig-zag lines straight (it is OK to have "top" parameters appear above the VI and have a vertical (straight) wire to their terminal(s)).  You might be able to simplify things a bit -- isn't there a Pulse Generator in the Waveform Palette that can generate the entire Waveform?  [I haven't thought this through, but there should be a method to generate a finite Waveform that you can cobble together ...].
Bob Schor
(635 Views)
