Generate PDF report with tables and array values
Hello Experts,
I would like to generate a PDF report after I finish running my data acquisition and analysis.
I tried using Report Express VI but it isn't helpful at all.
What I want is to have the average values of all parameters stored in different arrays to be displayed in a table in the report.
Example of report:
Header
Author
Voltage            1V
Current             2A
Temperature   30C
Thank you for your help ! Merci, amigo ! Smiley Embarassed
(6,952 Views)
I was not aware that LabVIEW could generate a PDF file!  You could write text to a file, formatting it as you wish, and then convert that text file to a PDF with other software.  You can also use the Report Generation tools to create a Report as an HTML or Word document (for the latter, you might need the Report Generation Toolkit) -- if you get it into Word, Word could possibly generate the PDF for you.
(6,900 Views)
https://decibel.ni.com/content/docs/DOC-4552
Does this document helps you?
I think there is no direct way in labview to generate PDF but it can create pdf using opensource pdf printer.
I think this should solve your problem.
(6,882 Views)
Thank you for the input guys. I really appreciate them.
(6,839 Views)
@J-M wrote:
2, 3 and 4 (1 was deleted):
http://forums.ni.com/t5/LabVIEW/exporting-graphs-programmatically-to-pdf/m-p/1276154#M531872%EF%BB%B...
This was a nice reference.  I followed up and saw that the reference 1, to generating a PDF straight from Excel using the Report Generation Toolkit, is the "1 was deleted" reference.
I've had a little experience calling intrinsic Excel functions using ActiveX (the hooks for which are provided by the RGT).  However, this is definitely not straight-forward, all the more so because it is getting harder to get "help" for the ActiveX functions, especially with "modern" versions of Office and with Windows 7.  For myself, I've learned to do a lot of Excel "manipulations" using the tools provided in the RGT, which results in much cleaner code, easier to create, maintain, and understand six months after I write it (always a good criterion!).
(6,815 Views)
I tried and recommend Simplicity AI PDF report creator tool. You can get it through VIPM. It really works great, is easy to use and reports don't need to be tied to revision control and MS Excel or Word Objects changing calls.
(6,799 Views)
