Generate/Read Digital Pulse - What clock to use?
I am using the NI cDAQ-9172 (with output module NI 9472 and input module (9421).   I am trying to generate a pulse, run it through a system (just a resistor at this point) and then read it back into labview.  I am able to generate the pulse with no problem, but anytime I try to read it I get an error regarding the clock.  Any suggestions?
(2,863 Views)
Accepted by topic author raging_engie
Looks like i figured it out.  I had the clock said as hardware timed, but my hardware was wired wrong.  After I corrected the wiring it worked, so that must have been the problem.
(2,837 Views)
