Generate Sound.vi from example code hangs..
When running "Generate Sound.vi" from example it hangs on second iteration on Sound Output Write.vi. No errors generated prior to hang. Using LabVIEW 2010.
CLD
(3,077 Views)
If you are running an 100% unchanged example, can you post the control settings in the front panel. The Labview sound system is somewhat flimsy. So if you write data to the sound card. In very small chunks it will most likely fail.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,060 Views)
On restarting the machine the sound vi worked as expected, thanks!
CLD
(3,024 Views)
