Generate TTL at a particular phase of a sine wave
Hi all,
I am new to LabView. I want to generate a TTL at a particular phase of a sine wave ( eg a TTL each at 45, 90 degrees etc). I use these TTL s to trigger my PIV image acquisition. Can anybody please provide me some guidelines to build the VI? Thanks in advance
(2,463 Views)
What type of output hardware do you what to use?
Greetings from Germany
Henrik
LV since v3.1
(2,451 Views)
I want to route the output TTL from my NI 6251 (through BNC connector) to PTU (programmable timing unit). PTU receives the TTL as a trigger to instigate PIV measurements.
(2,442 Views)
