Generate XML report using MAX Generate report.vi
Hi All,
Caught in simple and wierd problem. I'm using a simle VI called MAX Generate Reoprt.vi to generate an XML report but getting error
Error code -2147220553  Error description :Incorrect report file extension provided.
The image of the block diagram is attached. I'm able to generate HTML reoport from MAX(absolutely no probs).
Thanks in advance
Regards
VDC
(3,392 Views)
I THINK it just wants a .xml at the end of your 'file 1'. Give it a whirl, usually  I'd try it myself first, but my programming machine is down...sorry.
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(3,387 Views)
You must have the correct file extention. Here's what is wirtten in the detailed help of the function:
output filename specifies the filename of the generated report. You must have the correct extension for the type of report to generate (.xml, .htm, .html, or .zip).
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,382 Views)
Just add exetnsion of file you want to create eg:-Test.xml or Test.html
(3,061 Views)
