Generate a 1ms ts
I want to generate a triangle wave form with an 1 milisecond to sample time.
Can anybody help me with that?
I have a sbrio-9606 with a 40Mhz of frequency.
(4,255 Views)
Can you show what you have tried so far? There are examples. There are also tutorials.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,229 Views)
This is my code to generate a triangle wave form between[-10000, 10000].
And I want to the period is 1ms.
(4,126 Views)
The timed loop is currently set to 'ticks' - this means the loop will clock at your FPGA loop rate of 40MHz. If you right click on the structure and go to properties or double click on the timing icon on the top left you can change the clock period to 1ms.
(blog)
(4,109 Views)
 You may find this example helpful:
https://decibel.ni.com/content/docs/DOC-2387
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(4,055 Views)
