Generate a delayed pulse with analog trigger
I want to generate a pulse with counter when the gate of counter receives a voltage value which is generated by analog output chanel,is this possible??
I am using PCI-6713
Thanks!!
(2,724 Views)
You can generate a triggered pulse in a counter by sending a signal to the gate from the Analog output, as long as such analog output meets the operational contitions of the counter of the PCI-6713. Just make sure that the signal does not exceed 5V. The trigger on the gate pin will be taken as low from 0 to 0.8V and as high from 2 to 5V.
Thanks for contacting National Instruments!
(2,724 Views)
