Generate a formula
Generating the Formula of selected values with this logic!
  1. Create 1-D Array with 10 elements with AI voltage, DAQ, a0,a1,,,,a9
  2. Select the sampling time with t0,t1, t2…..t10
  3. t0  t1  t2  t3  t4  t5  t6  t7  t8  t9  t10  t11  t12  t13........t100sample time
a0  a1  a2 a3 a4  a5  a6  a7  a8  a9  a9  a11  a12  a13…….a100  values
  1. Farmula
A5^=Summation (a2+a3+a4)-Summation(a6+a7+a8) /100
  1. A6^=Summation(a3+a4+a5)-Summation(a7+a8+a9)/100
If “i” is the number of data values:
  1. Ai^=Summation(ai-3+ai-2+ai-1)-Summation(ai+1+ai+2+ai+3)/100
Message 1 of 12
(5,735 Views)
For loops, Index array, Array subset, Array sum and division.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 12
(5,730 Views)
Thank you for the reply!
Please see the VI attached.
In my VI I calculate A6^ value only how can I use the formula for many values or generalize it?
Message 3 of 12
(5,724 Views)
I have tried two methods now, in my new VI.
1. If I am using a large data set I do not have to choose the value with index array everytime
 for the value in concern it automatically:
takes the summation of first values of the current minus the summation of next three values, divide by 100
2. Is there any simple way?
Please see the attached!
Message 4 of 12
(5,716 Views)
Good start. Now you can add an Index-control to control your A[i]. The first element of the Index array will be i-3 and the 4th i+1, the others dont need any inputs as they per default will be [previous+1].
If you want the answer as an array you'll just need to wire your restlt to the for loop border.
/Y
Qestit Systems
Message 5 of 12
(5,713 Views)
How can I introduce index? Please can you modify my VI and show.
Message 6 of 12
(5,708 Views)
Minor modification to your 3rd loop/try.
/Y
Qestit Systems
Message 7 of 12
(5,700 Views)
Sorry can you send the modification in LV2009.
Message 8 of 12
(5,675 Views)
2009 version
/Y
Qestit Systems
Message 9 of 12
(5,667 Views)
Thanks!
Message 10 of 12
(5,661 Views)
