Generate a user event when push button is pressed
I have a program where I have a push button connected to NI DAQ and when button is pressed the DAQ reads it. Until the reading part the program is fine. When the push button pressed, a true variable will come out of the DAQ read and is given to a case structure. Inside the case structure, a generate user event is wired with a true variable and this is then given to register to user events and finally to the event structure. Inside the event structure, a boolean is wired.
You can see what I explained in the picture above. I have also attached the VI. When I run the program and pressed the push button, nothing is happening. So I ran it in highlight execution mode and I see the user event Push Button Pressed is never executed inside the event structure, but the true case of the case structure is executed which will generate a user event. But it is not executed in the event structure. Why is this happening? Thank you.
(1,525 Views)
Accepted by topic author govindsankar
Sorry, the program is wrong. I used the register for user event in the wrong way. I correct it by watching a youtube video. Here is the correct solution.
(1,521 Views)
Yes, in your first one you send the event before you've registered it and started listening, thus no reaction, and since you reregister i assume the same happens every time.
Qestit Systems
Certified-LabVIEW-Developer
(1,427 Views)
