Generate all colors from a start middle and end color
I searched and found a way to generate gradient colors with a start a middle and an end color and then generate the hex code of that color.
The thing is that I need to generate all colors that are close to the middle color, and that's why I used white as start color and black as finish color.
The thing is that to my surprise, I am not getting all the color values I need.
Can someone please help me generate all color value hex codes of the colors that are similar to the middle color value?
Message 1 of 10
(5,866 Views)
You did not attach your sub vi.
Its easier to do if you think in HEX
Splt numbers is your friend here take a color box constant split it into 2 U16s  Split those into 4 U8s Ignore the highest (it is 0)
Pick one R, G, B to remain constant  Red is the second U8 Green the Third, Blue the least significant.
Run the other two though something like this
Then join the numbers again (00-R & G- B to u16) and (00R-GB to U32) Bobs your uncle
You can play with inconsistent treatment of the tow variable colors.  You might not like it but it might be psychedelic.
Message 2 of 10
(5,846 Views)
I have taken a slightly different approach that what Jeff illustrated.
Yes start by splitting the colors into RGB values. Then create a ramp first between Red-Start and Red-Middle (do the same for the G and B) and then generate the ramp for Red-Middle to Red-End (same for the G and B).
Concantenate the R-ramps (same for G and B) then use the three resulting arrays in a For loop to "Join" the RGB back as colors.
No psychedelic effects and nice smooth color ramps.
Ben
Message 3 of 10
(5,822 Views)
This thread has a solution on this topic from Greg McKaskle himself.
Spoiler
From back in the days prior to LV 7 and the discussion forums did not support images let alone code sharing! Those were the days.
Ben
Message 4 of 10
(5,815 Views)
Can you please help me, by attaching the vi?
I am a complete newbie when it comes to hexadecimal numbers.
Thanks.
Message 5 of 10
(5,813 Views)
What I need is all the possible hex color values that are similar to a specific color.
Message 6 of 10
(5,808 Views)
Thanks.
Speaking only for myself... No.
1) I would be fired
2) I would screw up a perfectly wonderful and fun opportunity for you to learn about Hex.
Besides, it may not be exactly what you need. Code up what you can figure out, post when you get stuck and someone may be able to help you get over the rough spots.
And remember, Have Fun! After all you get a chance to code this up in LabVIEW.
Ben
Message 7 of 10
(5,801 Views)
https://www.screencast.com/t/oejlq5fs
Unable to display content. Adobe Flash is required.
Message 8 of 10
(5,797 Views)
No need for the FOR loop.  The Join Numbers will accept arrays.
Otherwise, my solution would be similar to what you already described.
Message 9 of 10
(5,758 Views)
I've used this set of code for doing color gradients in the past.
https://forums.ni.com/t5/Example-Programs/Gradient-Color-Ramp-Scrolling/ta-p/3524938
I don't think it does exactly what you want but might be more flexible.
Message 10 of 10
(5,744 Views)
