Generate dc voltage from user input using PCI 6221 card ?
Hello Nhanna,
If you would like to stop the output task at the same time as your control loop you should wire the stop button into the stop(T) input on the DAQ Assistant. The DAQ Assistant help says the following regarding this method:
"To optimize single-point performance when using this Express VI in a loop, wire this input to the same stop control you wire to the conditional terminal of the while loop."
Matt Anderson
Hardware Services Marketing Manager
Message 11 of 11
(435 Views)
