Generate event
Hi All,
I am using Labview7.0 and need to generate automatic event. It means without any button press or mouse move activity on front panel, i want to generate event after every particular time interval.
How i can fullfill my requirement??
Ratna
Message 1 of 10
(4,604 Views)
Accepted by topic author vijtin
One way you can fire the event is using value signalling property node of that control or indicator.
Message 2 of 10
(4,601 Views)
Hi Gita,
Thanks for ur reply, Can u please....upload the screen shot of block diagram for the same ???
Thnks,
Ratna
Message 3 of 10
(4,596 Views)
Hey gita,
I tried ur suggestion and its working fine.
     Thanks for ur helpSmiley Happy
Ratna
Message 4 of 10
(4,591 Views)
Hi Ratna ,
You can also use user events which allow you to fire events programmatically. Please refer to the attached vi for an example.
Message 5 of 10
(4,546 Views)
Hi Nitish,
Thanks for ur reply.  But I m not able to open the attached vi as i m using LV 7.0  and the version of attached vi is i guess LV 10. So can u please downconvert it to 7 or post the snap shot of block diagram n front panel.
Ratna
Message 6 of 10
(4,542 Views)
Hi Ratna ,
I am afraid dynamic event registration is not supported in labview 7. so i will not be able to downconvert my vi beyond labview 8. you can refer to the below mentioned link for using value (signaling) property. i hope this helps. Please let me know if you need more resources.
Regards ,
Nitish
Message 7 of 10
(4,538 Views)
Hi Ratna,
Dynamic event registration gives you increased flexibility in controlling how and where events are handled in your application. You can try the attachment. It should open in LV 7.0.
Joe
Message 8 of 10
(4,511 Views)
Hey Joe,
Thanks for the help. Its working perfect.
Ratna
Message 9 of 10
(4,504 Views)
You are welcome.
Sanjoe
Message 10 of 10
(4,490 Views)
