Generate output voltage with square waveform using FPGA (PCI-e 7842r)
I am new to Labview FPGA and I have a question regarding to signal generation:
Previously I have a PCI-6251 which I programed that by simply LabView. There is a "DAQ assistant" which I can generate voltage output with different waveform. The output amplitude is equal to the output voltage too.
Now I changed to PCI-e 7842r which I am programming it with LabView FPGA. However, there is no "DAQ assistant" with LabView FPGA.
I would like to ak if there is any VIs for LabView FPGA, say, generating an +/-1V AC signal with square wave of 30kHz?
Best,
Matthew
(3,045 Views)
There is a VI for square wave generation.  It does not take long to find it if you just look in the palettes while in the FPGA application context.  You just wire the output of the function to your output channel.
(3,038 Views)
