Generate the waveform using USB 7856 R
As am very new to the LabVIEW, So please help me to generate the voltage waveform.
I am using the NI USB 7856R to generate the waveform, as NI USB 7856R has 8 channels, I want to have 8 analog custom output waveforms( I have attached the waveforms please do check it), i have two types of waveforms one starts with the positive voltage and other waveform starts with the negative waveform.
i at single point of time i need one positive and negative waveform from two channels and next point of time it needs other positive and negative waveform with the same voltage levels from other two channels.. so on which form the 8 channels( 4 positive and 4 negative voltage waveforms ) which should be in loop.
(1,283 Views)
Can you attach your code screen?
(1,240 Views)
