Generating 9 dc signals in the same time
I'm wondering if there is a lab equipment that can generate 9 dc analog signals in the same time, I have an embedded system that should receive 9 dc analog inputs with different values in the same time.
Thank you
(2,583 Views)
Hi faisally ,
surely there is such "equipment"!
Do you have any special requirements?
Start with this one
(2,545 Views)
Thank you for your help, I'll check if I can get that.
(2,517 Views)
For testing purposes, you could just string a bunch of resistors in series as taps then control the voltage source to the network.
Vsupply Return<--^^^--+--^^^--+--^^^--+--  ...  --^^^--+--^^^-->Vsupply
With set resistances, all of the tap voltages will change with Vsupply as a percent of Vsupply.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,502 Views)
