Generating Triangular and sawtooth waveforms in FPGA
I need to generate triangular and saw tooth wave form in FPGA and give it to my testing system, But I cannot generate it, there are options for generating sine wave and square wave only.
I am currently using Compact RIO 9025 with NI9215,9263,9403 modules.
Pls tell me is that possible to generate those waveforms and if it is possible describe me how to do that.
(8,660 Views)
I am also facing the same problem.
(8,618 Views)
There are good documents that will help you get started with this task. There are, of course, many ways you can implement this and the right way will very much depend on your application.
Triangle Wave Generated PWM
Sinusoidal Waveform Generation with LabVIEW FPGA (Sine Generator Express VI)
If you need more to get started, I'd be happy to assist further, but I think these are enough to get you down the right path.
Cheers!
TJ G
(8,607 Views)
