Generating a clipped waveform
Hi all,
Any help with this problem would be much appreciated.
I'm trying to simulate the behaviour of a signal passing through an op amp.
Above a certain voltage, the signal should be clipped.
Does anyone know how to generate a clipped sine wave in Labview 7.0?
Thankyou.
Tony.
(3,744 Views)
Use the In range and coerce function (in the Comparison sub-palette), as in the attached example.
Chilly Charly    (aka CC)
(3,741 Views)
