Generating an array of main menu front panel control refs for passing to subroutines
Found it there also.  Thanks Darrin.  This is awesome and I agree with tbob - why isnt this thing on the tools menus.  It is somehting I would use in almost all my apps.
Message 11 of 23
(1,925 Views)
Now that I have an array of refs to each front panel object, how do I find a specific object's reference...by name?...by type?
Message 12 of 23
(1,921 Views)
tbob's request is slightly different than yours.
Adding it to the palette is a good idea.
Re: Nugget about using VI's in VI.lib...
Any or all VIs that are not on the palette are technically "off-limits".
Example:
THis code (LV 7.1 version attached), written in LV 7.1 uses the VI that writes the file to make sure the file is saved rather than waiting until shut-down to update the file.
That code will not even open in LV 2009 because that VI was not on the palette so it was removed.
So keep in mind that anytime you use a vi from vi/lib that is not on the palette, you can be locking your LV version OR delaying moving to the next version.
YOU have been warned (I wish I had been)!
Ben
Message 13 of 23
(1,919 Views)
By name and remeber if you re-name it the code looking for that control will break so show the caption and hide the name.
After fighting with that for a while you may want to look at my bundling solution again. Smiley Tongue
Ben
Message 14 of 23
(1,915 Views)
I still would like to know about some of these vi.lib hidden tools, even though they are specific to one version of Labview.  However I am glad that I was warned about it being version specific, thanx Ben.
What could be done is to copy the vi, and rename it to say something like "Get Refs_LV2009-only.vi".  But save it in a different folder, other than vi.lib.  When future versions roll out, and if something broke, the name would be a clue as to what to look for.
If it is off limits, I would not want to put it on any palette.
- tbob
Inventor of the WORM Global
Message 15 of 23
(1,884 Views)
We are not allowed to save off password protected VIs anymore.
Re: off-limits
Once we talk NI to putting it on the palette then it is fair game. The gotcha applies to "find-your-own" in vi.lib.
Ben
Message 16 of 23
(1,881 Views)
I agree with Ben, use the name to reference the controls if possible.  For me it is usually simple and effective since I am the only one touching the names and if I screw something up I get what I deserve.  With scripting, you can reference by type as well without too much difficulty.
About the vi.lib issue.  I was bitten in the butt by the config files, but it was more of a nuisance and by that time it was a well-known issue (just not to me).  NI's response was that we should probably be thanking them for doing it, as a user I saw it a bit differently.  I think we all agree that better (ahem, any) documentation would be in order.  For a while I was chastened and started pulling back on my usage and advocation of vi.lib VIs.  Then I had an epiphany where I learned to Stop Worrying and Love the VI.lib.  I figured that NI could pull the stunt with the config files since it affected a small portion of the users, but if everybody started using it then NI would have to take notice.  So now I tend to unashemedly push the VIs, but with the caveat that you know the risks.  You never want to be the one to recommend a bad restaurant and you don't want to be the one that pushes a VI that gets yanked arbitrarily by NI with no warning.
That said, if I weren't so busy (translation lazy), I would start a thread where we could post our favorite VIs from there.  You will find the documentation to be lacking at best and non-existant in many cases so we can try to fill the void with case studies.  Password protection is also a nuisance many times.  As a teaser, here are some of my recently used vi.lib VIs (and yes I have been playing with pictures a lot recently).  I think with enough buzz we can get NI to promote some of the vi.lib VIs to either the pallete or non-password protected status so we can use them without fear.
Message 17 of 23
(1,875 Views)
Thanks for the info Ben.  I would not try to use a vi.lib vi simply because they may change from version to version.  So if I can't save it off elsewhere, then I won't use it.  Too bad.  Now I see why you want to have NI put it on a palette.
- tbob
Message 18 of 23
(1,873 Views)
Here and here are two things which can save you a huge amount of time. Not dissimilar to the XControl Ben was describing, they will allow you to select a bunch of controls and instantly create an array or of cluster of references for them.
As for the vi.lib issue, you should consider that a popular hack does not necessarily mean it won't get changed. I'm assuming a lot more people modified the report gen toolkit, but NI still converted it to a library (although I get the feeling they weren't aware of people modifying it at the time).
___________________
Try to take over the world!
Message 19 of 23
(1,852 Views)
Darrin the VI you showed me creates an array of Gobject refs rather than control refs.  How do I get the GObjects to the more specific class without individually defining them?
Message 20 of 23
(1,802 Views)
